robitron929
- May 3, 2011
- 18
- 2
Proof^^^
[MOD] Better GPS Acer, more universal than cingular
Root required*
United states only*
Other countrys: You can still find a server for other counrties, Even states from https://support.ntp.org/bin/view/Ser...OneTimeServers Once you find a server copy and paste server apply were I say in instructions were it says us.pool.ntp.org.
Instructions: With Root Explorer go to /etc/gps.conf
In Root Explorer long press on the file and select open in text editor
Change the first line from: NTP_SERVER=north-america.pool.ntp.org to NTP_SERVER=us.pool.ntp.org
Save changes and reboot
ENJOY
Thanks to Unicornkaz, calebv2, mrvanes from xda devs.
FYI STOP USING FASTERFIX APP IT WILL SCREW YOU UP IF YOU APPLY THESE CHANGES ___________________________________
New. Try this and see how it works for you.
"Settings-->>Location & security" menu, there is the option to "uncheck" how the device determine your location...etc
1/ Use wireless networks
2/ Use GPS satellites
3/ Use location for Google Search
I have #2 & #3 checked
and I leaved #1 UNCHECKED
Root required*
United states only*
ENJOY
