RedTabletPC.com
- Feb 16, 2012
- 260
- 8
SmartQ S7 as the "Challenger" debut, claiming the same configuration as Kindle Fire, with IPS screen.
About S7 parameters- TI OMAP4430 dual-core processor, 7-inch IPS display (1024p x 600p) capacitive multi-touch screen,
Tempered glass panel, Android 4.0.4 system, 4gb flash memory, 1gb DDR memory, 2mp front camera,
Support for OTG, TF Card expansion and HDMI output.
SmartQ S7 weighs about 320g. Thickness of only 10.2mm (official data)
From left to right, respectively, DC power supply, Mini USB, HDMI output, TF expansion slot, 3.5mm headphone jack.
The huawei MediaPad high resolution IPS screen has been very good. The current opinion is that the S7 has a perfect screen.
S7 tablets display horizontal viewing angle of 170 degrees, vertical reach 160-170 degrees,
The preloaded Android 4.0.4 operating system runs very smooth on the Texas Instruments TI dual-core processor,
application's response speed is very fast, multi-point slide/Touch has no lag or sense of delay.
Performance option in settings can be independently set to operating frequency, so you can see current CPU performance.
More about SmartQ S7 tablets detail click here: smartq tablet pc
