I have the following tablet, green led at starting and red led when charging:
Model: Wonder Media WM8650
Android: Froyo (2.2)
Kernel: 2.6.32.9-default
Build: generic-eng 2.2 Froyo, ver1.5.3-20110819.012300
Cpu Info:
Name: ARM926EJ-S rev 5 (v5l)
Freq: unknown
Cores:
Architecture:
BogoMIPS: 797.97Mhz
Hardware: WMT
General specs:
Processor: VIA8650
Frequency: 800MHz
Memory: RAM 256M
Flash Memory: 2GB (* on 4GB: System: 2.23 GB, Local: 1.77 GB)
Speaker: 8 / 2W
Microphone: Internal
Reset Button
Power button voice + _
Display Resolution: 800*600
Screen size: 8 inch
TFT: Resistant touch screen
Touch screen: Supports resistive touch two points (*if hardware is compatible)
Camera: No
GPS: No
Bluetooth: No
3G: external 3G function
Video: Support 1080P Movie (mpeg...)
G-Sensor: 4 way G-sensor * (actually a WMT 3-axis accelerometer!?!?)
Network: WiFi IEEE 802.11b/g
Audio port: 3.5mm Headset
USB: 1*MINI 5PIN USB PORT 9V 1.5A DC-IN
SD: TF up to 32GB
Operating System: Android 2.2
Flash: v10.1 (evaluation version only, Adobe dropped the arm5 support for flash, this is the only version there is)
Adapter: DC 9V 2A
I have both skype and yahoo messenger installed, but I am not able to use voice, it says plug-in not installed, and it asks me, if I want to go to the market to install it now? by pushing yes, I am getting "the requested item could not be found". I will appreciate any help in solving the problem.
Cpu Info:
Freq: unknown
Cores:
Architecture:
BogoMIPS: 797.97Mhz
Hardware: WMT
General specs:
Processor: VIA8650
Frequency: 800MHz
Memory: RAM 256M
Speaker: 8 / 2W
Reset Button
Screen size: 8 inch
Camera: No
GPS: No
Bluetooth: No
SD: TF up to 32GB
Adapter: DC 9V 2A
