Thanks for the replies. I've done some more experimenting. Yes I have a sim card (Telstra) and the problem does not occur using mobile broadband. It's only if I switch right off and when I turn on,(at home) my home wifi is on and it tries to connect to that. I have to press Settings and Wi-Fi says 'Connected to ....' but unless I tap it twice and it then says 'turn on wifi,turning on,scanning,obtaing ip address from .....' and then presto it works. Could be a setting in my wireless router maybe. The only reason I turn it off is to conserve battery power. What do you reckon?
