Hi...
I had been using my tab for over 4 months without any issues. My wifi has suddenly stopped working (tab gets connected to the wifi but the the icon doesn't turn blue and the network is not up). I had recently updated to 3.2.1 but it was working fine for a few weeks on that too.
I changed my Wifi router security from WEP to WPA and also tried using static IP. I even did a factory reset (apart from the hard and soft resets) and I still have the problem. It is not rooted (and I don't want to do that yet) and since I'm not able to connect to the internet, I can't use any market apps to fix the wifi issue (even if there is one). Appreciate some help on this. Thanks.
