Advice For A 6.0-Inch Phablet Around $100?
Android-tech
Hi all, my iPhone 4S is really old and I am getting sick of the small screen of it. So I want to try an Android smartphone with big display this time. The display size should be 6.0-inch and above. And the price of it should be around $100, not over $120.
In my daily life, I use the phone to watch movie a lot, that's why I need the screen to be a big one. Besides, I want it has a durable battery life, strong WiFi signal and not overheated. A phablet will be better then I will not need to have a smartphone and tablet at the same time.
Do you have any good recommendation of it? Welcome to leave your comment and I will be appreciated for it.
Not going to happen at that price point. You can get a Nexus 6 for $200 and up right now, depending on storage capacity. Other 6" screen devices exist but they either don't have the battery life or are difficult to find.
@Jeffrey: Since the OP isn't going to get a phablet anytime soon due to being out of his price range, he might as well get a tablet.
What about vkworld t1 plus? vkworld t1 plus has 4300mAh Sony Li-Polymer Battery,Power House,
You don’t need to worry about the power or carry a heavy power bank when you go out. Just free yourself.
You can buy it from AliExpress for searching"vkworld t1 plus"
Not bad, thanks for your comment.I will consider of it.
