Allwinner A10 , problem with my G-sensor
issam80
Hi Everyone
I have an All winner 10 .. 10.1" screen running Android 4.0.4
If you rotate the screen, the display changes from portrait to landscape normally , but 90 % of the games won’t respond to the pad being tilted, like racing games or temple Run .
Does anyone know why?
Regards,
Hi Everyone
Regards,
Go into SETTINGS > DISPLAY > Accelerometer coordinate system > then select "Default coordinate system".
hit the back key and you should be all set. test out Temple Run after to make sure its playable
the "special coordinate system" is for older games and apps, and by default is selected.
Thanks for your reply , it already "Default coordinate system" and i tried the other option "Special coordinate system , to support other games" . and also didnt work :( . maybe cause my android is 4.0.4 version 1.4 , so these games are not compatible with the new sensor version ?
There are some games that just dont work that way. I have 4 tablets and 1 IPad2 and on all of them Angry Birds only works in landscape mode, none on any tablet or phone will work in portrait.
This is by game design not a issue on the tablet, so you may be seeing the same thing, and if this is the case with you like with Angry Birds there is nothing you can do about it.
