Does anyone have any experience with Pandigital's upgrade for Android applications? Does the installation they offer really void their warranty on the Novel?
Thanks,
john t
any hacking and customizing can void your warranty on any device, so if you want to be super save just dont do it but if you want to unlock the full potential of the device hack it.
Thanks for the rep[lies; obviously I have voided my warranty! My next question is what ebook reader do you recommend that I download for this device? Thanks.
John
I did hack it with the Android open platform kit; but now I have no clue how to get an ebook reader app back on the PD Novel! Can you please help?
Thanks, john t
After downloading the Android open platform kit on my PD Novel 7, I am at a loss as to how to get back to an ebook reader function. I would greatly appreciate any instructions how to do! Thanks, john t
Go to the following site and read the instructions, if this is not where you got your android kit. This will get you the latest firmware that has Barnes and Noble with it. You can then download and install other book readers if you want.
Thanks, I tried this by downloading to my SD card and placing card in Novel; but I am unable to open or install. Very frustrating. Any other suggestions is appreciated. Thanks
i installed a rom on one of them and had no problem installing apps right from the market including aldiko which i have used so my suggestion is flash a new rom
Did you read/follow the instructions? At what point do you not get the desired result? Are you doing the "press volume up and power key"? If you would give more information it would help others give you an assist.
