Android Tablet 2.2 will load websites but return to home page. Help?
msb08
When I enter a web address in my Android tablet it loads the website and then automatically goes back to the android's home page each time not allowing me to actually access the websites I enter. I've done a soft reset using the touch keys and then a reset using the pinhole on the side. How do I fix this issue?
Thanks!
Welcome to the forum msb08
It sounds as if you don't have a WiFi connection. But I would have expected you would get an error rather than just getting dumped back to the screen. See if you can use the Google Store app to download Dolphin Browser. If you can get it to install then WiFi is suspect, if you can then there is a problem with the browser you were using. That gives us a starting point.
