APad 8 imx51_bbg camera problems
dwop
I received this APad for xmas. It works great except when I try to open the camera I receive a process com.android.camera stopped unexpectedly. Does anyone know if there is a upgrade firmware that fixes this issue?
My firmware and tablet is as follows.
___________________________________________________________________________________________________________________________________
Kernal versian 2.6.31-01012-g4f92f83-dirtyroot@taojixiong-desktop#83
build number imx_bbg-eng 2.2 FRF85b eng.root.201101.01 013652 test-keys
UNKNOWN IMX51_BBG - IMX51_BBG*
*SYSTEM*
Model: Imx51_bbg
Manufacturer: Unknown
Device: Imx51_bbg
Product: Imx51_bbg
Brand: Freescale
Firmware: 2.2
API Level: 8
Processor: ARMv7 Processor rev 5 (v7l)
System RAM: 420 MB
*DISPLAY*
Logical Density: 1.0
Font Scaling Factor: 1.0
Pixels Per Inch X: 160.0
Pixels Per Inch Y: 160.42105
*CAMERAS*
Preview Size: 352x288
Picture Size Values:
Picture Format Values: Jpeg
Antibanding: Off
Flash Mode Values: Off
Preview Frame Rate Values: 30, 15, 10
Zoom Supported: True
Preview Frame Rate: 30
Flash Mode: Off
Whitebalance: Auto
Effect Values: None, Mono, Negative, Solarize, Sepia
Scene Mode: Auto
Jpeg Quality: 100
Focus Mode Values: Auto, Infinity, Macro, Fixed
Picture Size: 640x480
Effect: None
Preview Format Values: Yuv420sp
Whitebalance Values: Auto, Incandescent, Fluorescent, Daylight, Shade
Scene Mode Values: Auto, Portrait, Landscape, Sports, Night Portrait, Fireworks, Night
Picture Format: Jpeg
Jpeg Thumbnail Size Values: 80x60
Focus Mode: Auto
Preview Format: Yuv420sp
Preview Size Values: 720x576, 640x480, 320x240
Antibanding Values: 50hz, 60hz, Off
*GRAPHICS*
Renderer: AMD Z430
Version: OpenGL ES-CM 1.1
Vendor: Advanced Micro Devices, Inc.
Max Texture Size: 2048x2048
Max Texture Units: 2
Extensions: GL_AMD_compressed_3DC_texture GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_ATI_compressed_texture_atitc GL_ATI_texture_compression_atitc GL_OES_blend_equation_separate GL_OES_blend_func_separate GL_OES_blend_subtract GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_extended_matrix_palette GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_framebuffer_object GL_OES_matrix_palette GL_OES_point_size_array GL_OES_point_sprite GL_OES_read_format GL_OES_stencil_wrap GL_OES_texture_cube_map GL_OES_texture_env_crossbar GL_OES_texture_mirrored_repeat
*SENSORS*
*MMA7660*
Vendor: FSL
Range: 14.715
Resolution: 0.45984375
Power: 0.0 mA
