Archos 70 boots when charger connected
BlackAdder
Hi,
When I apply charging power to my Archos 70 (while it is off), it turns on and boots up automatically. I find this quite annoying, especially when I'm on the go, and charging possibilities are limited.
The reason is that when I start charging it, and it boots, I'll have to wait until it is completely up and running, so I can switch it off. Otherwise, it goes "to sleep", and slowly drains the battery.
I haven't figured out how to switch this feature off. Heck, I haven't even found anyone discussing this at all. Can any of you help me out here?
Best regards,
E
Most Android tablets turn on when power/charging is applied. For those that do, I don't think there is a way to stop it.
