iiDiabolusZz
- Nov 9, 2012
- 441
- 113
Thought i would start a new thread for all you v712 owners as there are post in all different threads -
Below is a guide from "dxueh" a friend from the chinese forums, he has used an external battery to replace his own but i have put a link to a battery which will fit, the original battery size as you can see in the picture is 4.0x71x90 mm so you could look for your own battery but max thickness it will take is 4.3mm as in the link, he also changed his wifi antenna the link for that is also below, all credit to "dxueh"
Battery - È«ÐÂÔ*×°LG AÆ· 436789 ´óÈÝÁ¿¾ÛºÏÎï﮵ç3200mAH 4.3*67*89 3.7V-ÌÔ±¦Íø
WiFi - ÁªÏëLENOVO ÓÅÖʱʼDZ¾ÄÚÖÃWIFI ÌìÏß Í*Ĥ ÐźźÃÊʺϸÄװƽ°å-ÌÔ±¦Íø
v712 bought some time, ever since the brush the 1.5 firmware basically no card white people depressed battery and WIFI signal. Battery now has to do not take the power can not adhere to one minute apart after seeing the battery drum kits, has withstood screen, affecting the screen, the battery reached to change not the point. Taobao battery and antenna yourself to put on. As follows:
3200 mA battery nominal maximum volume in the first test after fully charged play local video shut down automatically after four hours. The effect has exceeded my expectations, bought back strong, very satisfied. Replace WIFI antenna, the signal is significantly enhanced, and the previous router 2 meters are not full signal, no signal partition, not partition full signal, two cells of the wall, basically covering the range of activities and the effect desired.
Due to the bad I welding technology, replacement of the biggest difficulties is welding, especially very small antenna solder the figure below, the battery above detailed parameters of the battery, the way hair under my DIY mobile power:
Apart
Mobile battery internal
Has been replaced with
Battery antenna has been removed
Battery contrast
Antenna comparison
This image has been resized. Click this bar to view the full image. The original image is sized 912x684. |
Apart
Battery contrast
Antenna comparison
