bladerunn3r
- May 10, 2011
- 89
- 2
Little tip here. I take my tab to work for reading on breaks, where there are many wifi routers to conncect to - but they are either out of range or password protected. So if I leave my wifi radio on at work, it tries to connect all day while it's sitting in my briefcase- decimating the battery - so that it is down to 5 or 10 percent when I get home. But if I turn the wifi radio off while at work (since it can't connect to a strong enough signal for internet anyway) my battery will be about 80 percent when I get home. Obviously this is a huge differences for me - so now I always turn off the wifi radio when I go to work. Hope this helps.
Sent from my A100 using Android Tablet Forum
