Battery Replacement
If the batteries was in parallel it's not 7.4V it's 3,4 V. Only if the batteries was in serie you have 7,4V.
Oh ,Yeah, you are right man :)
Thanks for the advice
I missinterpretated the connection , its series :)
So 7,4 V is still right :)
Battery life would be much longer, but it won't fit in the stock housing.
I know that it wouldnt fit , but i would place the battery on the back of the tablett and drill a little hole for the cables of the battery
Hello, I have this WonderMedia WM8650 ANDROID VERSION2.2
KERNEL VERSION
2.6.32.9
BUILD NUMBER:
generic-eng2.2 Froyo Ver1.3.0-20110506.060727
I need to replace the battery.It also came with 3.7v series, can I buy the same battery you described? and how do I do the replacement.
