BBC iPlayer Help
debmcd313
Having received a pipo max m1 for Christmas I am really impressed as a new tablet user however having downloaded both the BBC media player along with iPlayer I am having no luck with the app and unable to view it. I am being requested to disable a setting in the web browser settings and am not sure how to do this. I would be really grateful if a fellow tablet/pipo user could help/solve my problem.. many thanks :)
I got this problem when first received my cube, I did a factory reset and it was fixed. I hope that this also works for you.
A factory reset is not the best way to solve this question there are many ways to get Iplayer working with BBC player on your tablet.
Don't use factory reset it put everything back and deletes all your apps on the tablet, try these apps in your tablet you will need a APK installer to install it.
BBC iplayer
https://dl.dropbox.com/u/106697397/bbc.iplayer.android.13014.apk
Flash player
https://dl.dropbox.com/u/106697397/Adobe Flash Player 11.1-111115012.apk
Also go on google play and download BBC media player app for free;) to watch your BBC TV
Please do you also have a dropbox link for the bbc mediaplayer?
I cannot use Google Play as it does not approve of my tablet.
