Bluetooth Help
bmcgregor3
Hi,
I have successfully discovered my S7 via bluetooth but cannot get the devices to connect because of invalid pin. Does anyone know what the default pin is for the S7? I have tried: 1234, 0000, 8888 and 1111.
Bruce
you can define the pin you want, just have to enter it the same on both devices.
What are you trying to connect?
I am just experimenting right now with my Motorola i880 nextel phone. Next week I am getting a Blackberry and would like to have the tablet and phone work together. I did not know that the pin had to be 'common' to make the connection so I was trying to figure out a pin for each device. I how have the two paired.
Thanks so much!
