Legomaniac
- Jun 7, 2011
- 1
- 0
I have recently run into a bootloop problem with my gentouch 78.
I can still manage to get into ClockworkMod Recovery v2.5.0.4 by holding the menu button as I use a mechanical pencil to hit the reset button. I however lost the sd card I was using fo the augen ages ago, so I have no backups, and no way of updating the gentouch.
All of the instructions I have found for updating so far are old ones from mid last year, that rely on updating the gentouch through a windows computer, but I can't even get into android, just clockwork recovery, so I have no way of following those instructions.
Does anyone have a backup rom from a current functioning gentouch I could apply? I have the 2.5 mm headphone jack (earlier) version. I'm assuming if you just boot into clockwork recovery and backup with nandroid that you could snag a backup image that would work, since I already have the ability to restore in nandroid.
Thanks in advance,
Legomaniac
Thanks in advance,
Legomaniac
