Browser Problem after Upgrade
britinva
82
So upgraded to ICS (v4.0.4) and using stock browser. Started having issue with websites being forced to mobile sites not desktop. Checked using the about:debug command and its set to Desktop. Anyone else got the same issue?
That's an old problem. Get ICS Browser + from the Store. It looks the same, more or less, but setting the desktop mode sticks like it should.
Also anyone know if a way to reprogram the Internet key on the Keyboard dock for a different browser?
So ICS rather than Dolphin?
I only suggested that as a direct replacement if you were happy with the default browser, other than the mobile site issue. I would suggest Dolphin Browser otherwise.
So does anyone know if a way to reprogram the Internet key on the Keyboard dock for a different browser?
