Hello all ^^
I own a dual-touch captivescreen s7 with no intergrated SD (i have an 8gb microSD card inserted) , and I'm currently facing couple problems which I'm couldn't find any solution or discussion to them so I was hoping if anyone could have some input on this.
1. captivescreen bug:
There is a person who uploaded a video regarding this issue; when bottom left and top right's clicked , the axis jump to top-left and bottom-right and 2 axises cannot switch positions from a rotation, so during game plays such as pocket legends, it often mis-click on things
here is the video link
From what I can think of is that, since Taiwanese rom is also locked in 2-way rotation, could it be what's causing the problem? so I was wondering if anyone else is having the same problem?
2. TuneinRadio stop playing/freeze/system hang then restarts:
It's just when I play musics it randomly stops or hangs, regarding if I'm using wifi or 3g, I think it might of being cache overloading or something? but I don't know how to fix it and it seems most people are happy using TuneinRadio with no such issue.. so I was wondering if anyone had encountered such problem?
I have rooted my s7, but I have not yet used app2sd or link2sd because I'm not very technically smart ....
the reason I rooted is because my s7 came with a build-in free version of document-to-go, and I could not upgrade or install my paid version of the software so I had to root it and remove it manually before I could install the full-version
If anyone's facing that problem, this way could fix it ^^
Thanks guys
Thanks guys
