Dear all,
help is needed since my new Onda V811 can't last for more than 2 hours.... i'v checked the battery Usage, and surprised to found that 80% of my battery is used by cell standby, so, immediately, i activated the Air Plane Mode without any progress...
i searched a lot on the net, and reached to the result of deleting the phone.apk, telephonyprovider.apk, dialer.apk, also some suggest to modify and text file ( i forgot its name) from nophone=false to nophon=true....
for me all those procedure makes a sense, BUT the main problem now, to do it, the tablet must be rooted... and i failed to root it...
so, it will be a great help to advice me how to root my Onda V811, or how to stop cell standby from draining the battery....
Update: i tried the method in the "**New** Root and Full Working Play Store and Google Apps/Root-Explorer
" thread, and i put root.zip and factory... in the SD Card, and went to recovery mode and choosed update from TF Card the root.zip and restarted the Tablet, without any progress!!!
Emran Matalka...
Emran Matalka...
