Clever people - please help - simple questions!
t419kgo
:confused:
Right - I picked up my 4GB MIDX51 about 6hrs ago.
I have no clue what I am doing....
Have got the WiFi working but I need to "right click" on things, and clearly I cant!
Main use will be to take images from a digital camera/USB and save onto device.
Then store some there, and take rest off device and place onto a USB
I CANNOT WORK OUT HOW TO SAVE IMAGES ONTO THE DEVICE???
As soon as I take the USB with images on it, out of the machine, they all vanish??
I have been using laptops/PCs for years, but am stuck and very frustrated.
Please help before I throw it out the window
I only got a silly little start up users guide with it
xxxxx
Kelly
I
you usually need root to move things around on the internal memory so first root your device. Second if you are plugging in a usb jump drive with pictures on it and your tablet sees the pictures you might be able to copy pictures from the usb stick to the sd card in the tablet and then that way they will be on the usb stick and the tablet
Root........how on earth do I root it? I don't even know what it means.......!
I can use pics as wallpaper and they save once the USB is out, so it must be possible??
8hrs after I started, I still have no idea!
Or, can anyone point me towards an online user manual?
I feel the same way-can't save my photos on my 9.7 Android tablet-help-in simple words! Did anybody ever respond-that was in Jan-
