Hi,
Thanks to everyone for the help, I have been reading this site and have got much help, but im stuck and need some assistance
I have tried to root my tablet 7042-4, and all seemed to go well, but its does not seemed to have actually done anything.
I followed the instructions here http://www.androidtablets.net/forum...ead-first-development-index-root-utility.html
Its all connected ok and it copied the files ok, but I think the rooting process ran out of space on /system
shell@android:/data/local/tmp $ df
df
Filesystem Size Used Free Blksize
/dev 407M 44K 407M 4096
/mnt/asec 407M 0K 407M 4096
/mnt/obb 407M 0K 407M 4096
/system 251M 251M 4K 4096
/data 1G 249M 1G 4096
/cache 503M 8M 495M 4096
/mnt/sdcard 4G 68M 4G 4096
/mnt/extsd 7G 168K 7G 4096
and now su is too small and I get a segmentation fault when I run su
shell@android:/data/local/tmp $ dir /system/xbin/su
dir /system/xbin/su
-rwsr-sr-x root root 4096 2013-06-08 00:08 su
shell@android:/data/local/tmp $ su
su
Segmentation fault
original su is about 21k
139|shell@android:/data/local/tmp $ dir
dir
-rwxrwxrwx shell shell 843503 2013-06-06 21:06 Superuser.apk
-rwxrwxrwx shell shell 33554432 2013-06-07 23:46 boot.img
-rwxrwxrwx shell shell 16777216 2013-06-07 23:46 bootloader.img
-rwxrwxrwx shell shell 1075144 2013-06-06 21:06 busybox
-rwxrwxrwx shell shell 216 2013-06-06 21:06 install-cwm-recovery.sh
-rwxrwxrwx shell shell 222 2013-06-06 21:06 install-stock-recovery.sh
-rwxrwxrwx shell shell 10276 2013-06-06 21:06 mempodroid
-rwxrwxrwx shell shell 105 2013-06-06 21:06 reboot-recovery
-rwxrwxrwx shell shell 33554432 2013-06-07 23:46 recovery.img
-rwxrwxrwx shell shell 445 2013-06-06 21:06 root.sh
-rwxrwxrwx shell shell 22364 2013-06-06 21:06 su
-rwxrwxrwx shell shell 110128949 2013-06-07 23:46 system.tgz
The Tablet does boot up and work ok, so no problems there.
Finally managed to get the /system in rw mode, but of course can not edit or move anything in there
is there a way of increasing the size at all?
/dev/block/nandd /system ext4 rw,relatime,user_xattr,barrier=0,data=ordered 0 0
Thanks for any help
Chris
df
dir /system/xbin/su
su
Segmentation fault
dir
Thanks for any help
Chris
