suedemonkey
- Dec 7, 2012
- 6
- 2
Hi Guys and Gals,
I am a Noob and I just got my Coby Kyros MID7036. I got the device because it is very inexpensive and practical for my needs. However, I have found out that there is a chance to maximize the gadget. In a nutshell, these are the things I need to do to maximize the tablet :
1. Create a System Restore file or System Dump to have a back-up just in case Rooting does not work.
I still have to do some research on this one to find out a Coby Kyros MID7036 specific way of creating a DUMP. Although I am not sure if having a SYSTEM DUMP will enable me to restore the tablet to stock settings if I encounter problems in ROOTING, but having a back-up might help me in the future.
2. Root using this simple steps : http://www.androidtablets.net/forum...pps-telechips-7032-7034-7036-7048-8048-a.html by vampirefo.
The vampirefo. way is the best and simple way to root that I have found so far. As far as I know, rooting the device will allow me to maximize capabilities giving me root access. This will also enable me to access GOOGLE PLAY so I can download more popular apps for Android.
These are the things I have researched so far, I am still trying to understand a few things before I go ahead and root my device. But I have a few questions for you guys if you have time to help out:
1. Is there a Coby Kyros MID7036 specific way of creating a System Dump or the System Dump I have found for other devices will also work for my device?
2. Am I right to assume that if in case I will have problems with the root or I want to go back to stock settings, I just need to re-install(?) the System Dump I have saved?
3. Is it also true that Rooting a device will open it to Virus and Malware?
4. Is there anything else I need to do to maximize the tablet? I just need to have access to Google Play for the Apps and games.
Thank you for taking the time to read my post and I hope to learn more about my device so I can make sure I don't brick it or something.
Cheers!
Cheers!
