well the problem of this coby kyros 7048 is that the auto rotate is not working ( checked or unchecked in the settings ) and the other problem is that it does not read sd card for some unknown reason like cam is searching for sd card to use.
I can view the sd in the es explorer location "/mnt/ext_sd/", root sd card "/sdcard/" folder says its empty or not mounted and "/mnt/sdcard/" is empty as well.
tried to search on some same problems but didnt find any answer regarding to my problems.
this is my adb mount and Is dev/block/ (idk if its needed but it was asked on the other post i viewed)
mount
rootfs / rootfs rw,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mtdblock2 /system yaffs2 rw,relatime 0 0
/dev/block/mtdblock5 /data yaffs2 rw,nosuid,nodev,relatime 0 0
/dev/block/mtdblock4 /cache yaffs2 rw,nosuid,nodev,relatime 0 0
/sys/kernel/debug /sys/kernel/debug debugfs rw,relatime 0 0
/dev/block/vold/179:1 /mnt/ext_sd vfat rw,dirsync,nosuid,nodev,noexec,relatime,u
id=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset
=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
ls /dev/block/
loop0
loop1
loop2
loop3
loop4
loop5
loop6
loop7
mmcblk0
mmcblk0p1
mtdblock0
mtdblock1
mtdblock2
mtdblock3
mtdblock4
mtdblock5
mtdblock6
mtdblock7
mtdblock8
ndda
platform
vold
this is my vold.fstab
# External NAND Storage
dev_mount nand /mnt/sdcard auto /devices/virtual/block/ndda
# External SD card
dev_mount ext_sd /mnt/ext_sd auto /devices/platform/tcc-sdhc
# External USB storage
dev_mount usb_sda /mnt/usb_sda1 all /devices/platform/dwc_otg /devices/platform/tcc-ohci /devices/platform/tcc-ehci
dev_mount usb_sdb /mnt/usb_sdb1 all /devices/platform/dwc_otg /devices/platform/tcc-ohci /devices/platform/tcc-ehci
mount
ls /dev/block/
loop0
loop1
loop2
loop3
loop4
loop5
loop6
loop7
mmcblk0
mmcblk0p1
mtdblock0
mtdblock1
mtdblock2
mtdblock3
mtdblock4
mtdblock5
mtdblock6
mtdblock7
mtdblock8
ndda
platform
vold
# External SD card
