Hi there,
Where to begin? I'm exasperated with this thing and ready to see how long it would take my 5 year old to destroy it with a mallet.
After days of futzing and fiddling I managed to root the thing and get the market to work. But in doing so I think I caused more problems than I solved, so I attempted to revert back to factory and start over, but now I'm halfway between rooted and stock and none of the problems I have with this thing are resolved. Here are the problems I'm having in no particular order:
1. Many of my apps including things that should run and do run just great on my Huawei Ascend II (which is a gutless wonder compared to most devices) such as Angry Birds Seasons and Space, Bejeweled, Chuzzle, etc either refuse to open at all or just crash and drop me back to the home or apps screen within a few seconds of launching.
2. As I mentioned above, I can't do a factory reset on this thing. I attempt to open the update file on the device by selecting Settings->About Device->System Updates->From Nand Storage (or SD, it doesn't matter) and it will reboot into recovery mode, find the update, verify it, then stop about 25% of the way thru and abort.
3. There is NO update.zip on Coby's website ANYWHERE that will work with this hunk of junk. The only one I can find is for the 7015 which it of course won't install and does the same thing as the stock recovery image I mentioned in problem #2
4. Netflix runs like Molasses in January on it, but that's a problem with Netflix I think from all the googling I've done.
There's more but these are the main issues I'm having. At this point, I just want to get it back to stock so I can give it to my kid and go buy a real tablet (unless someone out there has a miracle ROM image or other magic fix that will transform this turkey into something usable). Any help you folks can provide would be great.
Thanks for looking,
-Phil
Thanks for looking,
-Phil
