Colby 9742 Problem (Mirrored)
Playa82
Hello Guys,
i got a big Problem with my tab. After i flashed this ROM yesterday:
http://www.androidtablets.net/forum/coby-generation-3-development/42314-9742-stock-custom-rom.html
I flashed this, cwm recovery -> 9742_Mobiz_V.2.zip -> 9742_boot.zip
Now the touch is mirrored. That means, when i touch the upper right corner, i actually press the lower left corner. I added 2 Pics, to seen what i mean. Same goes for unlock. I have to toch left to unlock the tab instead of right.
Can somebody help me please !
I hope you made a system dump before you flashed the Mobiz ROM, because the solution to your problem requires it. If you didn't using one of the available 9742 dumps may work but is not guaranteed.
In short, unzip the dump and ROM. Copy the libs from the dump into the Mobiz ROM and zip up the Mobiz ROM. Then copy the new zip to the MicroSD and install. That should fix your issue.
P.S. I don't recall having to change the boot image when I did this, and don't believe you have to either. There should be no harm either way.
Damn, i didnt made a dump before.
btw. you mean the whole lib folder, right ? Should i copy it and overwrite, or erase it and paste the dump lib ?
tried a few dumps from your thread, but it doesnt work. it hangs at the android boot animation...
Any other solutions or help ?
Delete the existing lib folder and replace it with the one from the dump, but without a dump specific to your tablet you're screwed unless one of the existing dumps works.
Consider this a lesson learned. With Coby out of business, there is no warranty on your tablet at all. Now, more than ever, people have to read the information we provide in the sticky posts, unless they want to be out the cost of the tablet.
Did you used LiveSuit too?
Or just copied the module files to system/vendor/modules?
i used livesuit. but i copied no files. just add the custom rom image to livesuit and get your tab in the dl-mode the way it shows in the video. that really works like a chram. that was my last chance and it works now :)
Hi Playa, congratulations on getting your tablet problem solved and welcome to the forum. Glad you decided to join us here at Android Tablets.
BTW When you get a chance, please go to your profile and fill in the Tablet / Device entry. That way folks will know which tablet you have without you having to tell them every time.
Playa,
Where did you get your LiveSuit IMG file for the inverted (mirror) screen issue?
I used LiveSuit and now have the same issued.
Tablet: Coby Kyros MID9742 8gb
Thanks for any help,
