Complete Novice need help
coinneach
Hi Everyone. I am new to this forum and a complete novice with Android Tablets and as a result need some help. I have just purchased a SuperPad VI and cannot get it to start. Unfortunately there was no user manual in the box. It appear that the battery is charged as the indicator is green, on the screen is a circle with a cross in it, similar to the cross hairs in a telscopic sight, in the bottom left hand corner are three icons and the bottom right is the SD card indicator and the clock, but I cannot get any further. Any help or advice will be appreciated.
coinneach.
Hi coinneach, congratulations on your new SuperPad and welcome to the forum. Sorry to hear you're having problems with it. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you get that tablet running properly. Good luck!
coinneach.
The circle with a cross in it may be how you start, touch it and swipe to the right.
