ShawndaDeeJay
- Dec 27, 2011
- 4
- 0
Question 1: I just got gifted the Craig Wireless Netbook, powered by Android 2.2, does it need an sd card to download adobe and other apps?
Question 2: How do I cancel downloads?
Question 3: The instruction manual that came with it doesn't really describe anything ; Is there a link to where I can find a betteer description of how to work it?
Question 4: My netbook is running really slow if I add a Sd/MMC card (supports max 32gb) will it speed my system up?
Thank you
Thank you
