cruz firmware update help
corey
did the update it starts to load and then stops with adroid guy and white triagle with exclamation point will not flash to anything
I had mine do that once, took out the external SD card and it worked
Sent from my slatedroid-pdn using Android Tablet Forum App
What one you take out depends on what firmware you had prior to the attempted flash. In my case it was the internal...as i had some of the mod OP firmware.
