D2 tablet problem
poopshoopcoup
Apr 11, 2014
I have a D2 727 tablet and I had to factory reset it and ever since my Google play store will not download apps. When I choose any type of app a box comes up saying " error invalid file." I factory reset it again and I have cleared all the cache from the Google play store itself. I also disabled the update and reloaded the factory version. Nothing is working? What do I do to fix this damn problem? Anybody please help?
Log into the Store on the WEB site and pick an app. See if it displays your D2 as an installable device. If you want that app and your D2 is displayed trying installing. If none of the above is working double check that you are using the same credentials on the tablet that you are on the WEB.
