kodiakblair
- Mar 16, 2013
- 4
- 0
Hi I've got a Flytouch 7 with 10" screen 1Gb ram and a 16Gb drive running ICS. I've had it about .7 months and the battery is dead. It won't charge or run from the charger. I've tried a different charger to no avail. Has anyone had any luck replacing the battery. If so how did you do it and what battery did you use .I've nothing to lose trying this myself as the vendor refuses to reply. Beware buying on Ebay they make their money from the sellers and don't get involved after 45 days. So your years warranty means nothing if the seller just blanks you. Anyway any help would be great. Cheers K.B
