DMEDIA ATZ 1421 battery issues
satai
14
Hi everyone,
I just got my first tablet (secondhand).
It's a DMEDIA 1421 with a samsung Cortex 1Ghz cpu and 4 gb.
it's worked perfect for about 2 weeks till last sunday.
I was playing some jewel game and ignored the low battery warning thinking it had enough juice to play some more levels.
Suddenly the tablet closed down and powered off, i then recharged the tablet thinking it could take a while since the battery was completely drained.
The next day i powered it up and saw that the energy level was at 3%.
i then let it charge for about 36 hours wth the same result.
When pluged-in the indicator is animated and it also says charging on battery-status.
The strange thing is that when i unplug the tablet, the energy indicator will raise to nearly 25% and when i plug it back in it will drop to 3 or 4%.
I did some deep research on google and red some tips on how to regenerate li-ion batteries.
I followed one tip where i had to disconnect the battery.
After i opened my tablet and removed the battery i noticed that when i connect the power adapter i still get battery specs under advanced settings/ battery information.
So figured out that the problem must be in the tablet and not the battery.
If anyone has any tips on fxing this i would be very thankfull.
PS.
I called the helpdesk and they did send my some new firmware that i installed several times wih no solutions to my problem, called them back, got a promise to be called back but still waiting for the call.
