Eliminate the power button wake and/or slide lock
Jun 29, 2011
135
Widget Locker allows eliminating the need to use the power button to wake the device as well as, if you want, eliminate the slide lock.
Enable volume buttons and home buttons to use the features. Tap your volume button to wake the device, eliminating the concern of the power button wearing out that concerns some. By enabling the home button this adds the ability to unlock your tablet to the home screen by tapping the home button or to where you were when the device went to sleep by tapping the back button.
I can confirm this works on froyo and gingerbread as well as honeycomb.
It's available on the market, Amazon app store and GetJar, though I'm not sure if the latter has the latest update
Support Our Troops!!!
Sent from this Galaxy via Tapatalk
