Epad Flytouch Start Up sound
Terry07
Hi
Is there a way of switching off the buzzing noise when you switch on the EPAD. Its too loud!
I think its a vibration. You might be able to find a different ROM that eliminates that, but I'm not 100% sure. If your up to flashing it.
This is an old thread, but has anyone figured out how to do this? I agree, the buzzer is annoying on start up and shut down.
Dan
no control with the software, you need to open the tablet to disconnect the vibration, or you can mod the vibrator motor add some soft foam to eliminate the buzz sound.
