FYI:
I'm running several external batteries to my tablet.
The primary one I use is a rechargeable 9800 mAh @ 12VDC (118 Wh) CCTV battery. The CCTV battery uses it's own plug-in external transformer (mine is 110-240 VAC). You can get them for about 40$. I'm not sure how long it will work for - I can run the tablet with WiFi/Skype/Movies for over 8 hours and still have a 100% charge in the internal tablet battery. They are very small and light.
Example:
http://www.ebay.com/itm/12V-DC-Rechargeable-Li-po-Battery-CCTV-Cam-9800mAh-/280805158576?pt=LH_DefaultDomain_0&hash=item41614aaeb0
I used this power cable:
http://www.bixmart.com/DC-Power-Cable--55-x-25mm-to-30-x-11mm_p_262.html
* I had to put a tiny bit of aluminium foil in the center-pin as the inside pin is barely long enough. Make sure NOT to 'short-it'. If you do not do this then as you move the wire the power will be intermittent to the tablet.
I'm not using a DC-DC regulator but thus far the voltage drop has not been an issue (12.6 VDC fully charged, 10.1 VDC near discharge). The tablet charges to 100% then indicates being plugged in. You can get DC-DC regulators if its required.
I just tuck it into the fold-able case. I might use velcro in the future.
Great if you need to run a long time without power - say on a international jet flight or when the power is out (ie: watch some movies during a hurricane). Also as the tablet, the power cables and adapter give off VERY strong magnetic fields when plugged (to about 2' out) into the AC I only use it when running off DC. Great if you're electro-sensitive or would like to avoid that.
Also saves the internal battery as Li-Ion batteries are only good for about 600 charge cycles.
* A full charge is over 15-hours, so get two or three and swap as required if you will use them everyday. Also, make sure to charge in a safe location as sometimes Li-Ion batteries can go "poof". I measured 10.8 VDC on the battery when my tablet began to use the internal battery. As with a full-charge the voltage is 12.6 VDC and near-dead it is 10.1 VDC. It's actually good that it SEEMS to stop at 10.8 VDC as I don't to fully drain the battery.
EW
Example:
EW
