Fastboot problems on Android and PC
kaybee327
45
First on Android Aishuo A816
Have 2 boot problems first have to go into recovery menu and do a re-boot. then it works . Ordinary boot hangs with the 2 superhero androids.
Use power+menu to boot into fastboot but will not work, starts off ok but then hangs at :
FASTBOOT update system
Bena mid-device-001
Have to power off to get out of it.
On PC
First of all ADB works fine can pull push or flash but when I type fastboot devices nothing happens just go back to cmd prompt. When I type fastboot I get the help menu so it seems to be 'installed' OK but can not connect to android.
Have been searching for an original firmware to make a backup SD jus in case I F** up but cant find one. All the images I can find have a boot img and system folders.
Can anyone help please
Keith
