Firmware upgrade from Xenophon wiped my entire tablet and SD card. :-(
CaptainVimes
27
Is it considered normal for the firmware upgrade on the zenithink website to format/factory reset the tablet?
If so then I'll stick with the version I've got :lol: if not, then what did I do wrong? :eek:
It took an entire day to re-install all the stuff I have on it, (I'm a hoarder) so if it's normal for it to wipe everything, what do you guys do about everything you have installed?
sent from my Zenithink C91 (Upgrade) Tablet,
using Xparent Purple Tapatalk 2
Firmware upgrade some time wipes the tablet data but it's strictly preferred to remove SD card while Firmware upgrade.
So I would need to get another SD card just for updating the firmware? As you need the file on the SD card when you do the upgrade.
I have carried out the latest firmware upgrade on the C91 Upgrade from the Zenithink site (The '0327') - during the installation it gives two options:
- com.android.provision.DefaultActivity or
- Setup Wizard
Chose the second option and it seems to have carried out a total reinstall; have had to reinstall all of the apps and settings:
Any clues as to which option is correct.
