Galaxy 10.1 Screen Flicker Problem
Sep 27, 2012
Dear Folks,
I am experiencing strange problem with my Galaxy Tab 10.1. Few days back, my screen start flickering and when i talk with peers , they told me it may be because of some specific application. Later it gets increase. so, i try to restore it to Factory Default setting. Flickering gets reduce but after couple of days, it appears again.
And today, suddenly it increase to many extend and finally i cant see my screen anymore !!!
attached picture is a current status for my galaxy tab !
I dont know, how to bring it back to original format.
Although, i can hear starting sound and when i am clicking, i can feel, its working. I dont know either this is something specific to screen, battery or something else ?
Any help or suggestions !
Guys,
Need solution for this problem ! i cant do anything on my tab ! all of a sudden screen appear but it went off again in few seconds !!
is it repairable !
Guys,
is it repairable !
Hard to say what is wrong but anything can be repaired. Question is, you or Samsung. ;) If you have an HDMI port and cable see if you can get a display on a TV.
I have the same problem. Not found a solution yet. I`ts happens after some time after tablet warmed up. 2-3 min
On the surface that sounds like a heat related short or open circuit. I would suggest an exchange ot RMA for repair.
what, if we ROOT the Flash and recreate the partitions ? is it worth to apply.
I checked with Samsung service center, they told me cost RS 35,000 ! 368 US Dollar, too much !!
As far HDMI concern. so, i dont think its possible with Galaxy Tab !
If you do a factory reset and the problem is still there no amount of rooting or other ROMS will help. There is an old saying, "stuff happens" ;)
