AceMcCrank
- Sep 26, 2012
- 4
- 0
Augen US links are dead now, same with the randomtechinfo links, making it difficult to maneuver around here. Hopefully you guys have the files hosted somewhere else and I'm just not finding it.
I can get to the recovery screen if that helps. And I am a complete newb to the SDK, making it hard to use at the moment. Step-By-Step instructions seem to not be working for me, even though I set up the variable "adb" for the %systemroot% path I installed it to. I still have to manually browse through cmd to platform-tools. However, I digress...
What I need is the "update_intson_android.zip" file, or equivalent. I have a MicroSD card, so that's not an issue. I'd move files over, but the device won't let me browse to any "3" of the displaying drives when I plug it into my computer using the Motorola drivers technique (thanks, by the way. I got that one from here.) If nyone has it hosted elsewhere, or has a better suggestion (I know the default Andoird OS had some issues) It'd be greatly appreciated. Thanks!
Further info: from what I can gather, it's a Gen 1. Th second model came with a 3.5 mm jack, from what I understand, and this one has the 2.5 mm jack.
