Repost from the wrong forum... please dont flame!
The Tablet I have (P752) is the same one from the Groupon as well as the one in the 2nd video posted... it is the most frustrating device of life.
I was tempted to make a new post, but it seem frustration is gathering here. Hopefully I can help you guys out with what I have learned... in the hopes that someone can help me out with a new rom to replace the garbage system it came with.
(p.s. this groupon tablet makes my ARC look like a joke to mod).
Groupon "information" :
Seller:
ZoomaFX (D.N.G Superpad i7 7″ infortm X210 Flytouch Android 2.2 512MB 4GB WIFI HDMI Camera Tablet pc | Zoomafx)
Dealer listed specs (Specs According to seller) :
D.N.G Superpad i7
1.Infotm IMAP X210 1.0GHZ
2.Google ANDRIOD2.3
3.512MB 4GB
4.USB 3G built in Camera with G-sensor
LCD Display:7 inch 800X480
CPU:infotmic X210,1GHz ARM11, Support hardware 2D/3D graphics acceleration
Operating System: ANDROID GOOGLE 2.3
Memory:512MB
Storage:4GB
Language:support multiple language
Touch panel:TFT Resistive Touch Screen
3G:EVDO:E1916,ZTE:AC2736,HuaweiE1750
I/O Port:USB 2.0 2, HDMI 1,
Headphone 1, MIC 1, DC JACK 1, TF card reader
Network: WIFI:IEEE802.11b/g wireless network
Camera:Built-in two million pixels camera
Audio:2.5mm headphone jackHigh-quality stereo loud speaker Built-in microphone
Media File:Audio : MP3,WMA,WAV,APE,OGG,FLAC,AACVideo :AVI,3GP/MP4,MPG,RM/RMVB,,MKV,MOV,FLV,WMV support multiple formats 1080P
Video HD Output:HDMI 1080P Output
Power adapter:Battery capacity:3000MAH
Battery:standby time: above 3 hours,Video play last :3 hours
Boot sequence:
1) Green android text.
2) Green android robot with dots in background.
3) Grey android text that almost pulses.
4)Homescreen.
Factory Resetting this tablet:
IN ORDER TO RESET:
hold down the button on the front, the Home button (H button closest to audio jack) and while holding these two down press the power button. If done correctly white text will appear on your screen. release all buttons and factory reset will begin.
Communicating with device:
ADB WILL be able to communicate with the tablet once you have all the requirements installed.
You need to install the OTG driver supplied in earlier posts ( comes with IUW burning tools)
1) Install android SDK Android SDK | Android Developers
(NOTE: YOU WILL NEED TO HAVE JAVA SDK INSTALLED)
1) Plug the tablet into the computer while ON.
2) Go to Settings> Applications > Turn on UNKNOWN SOURCES.
3) go into Development Menu. Enable USB Debugging.
4) Go to device manager.
You should see a device listed as "MID".
5)Go into the properties of this device and install new driver, select the available driver from the unzipped burning tools folder.
Removing Cell Standby ( Useless phone junk that is on there) :
You will need:
Root access
R/W filesystems
ADB + SDK installed, MID driver installed.
issue the following commands from ADB Shell:
1) SU
2) mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
3) rm /system/app/Phone.apk
4) rm /system/app/TelephonyProvider.apk
5) errors WILL appear on screen. Reboot tablet and you should be all good.
Rooting the Tablet:
This tablet can be rooted.
in order to do it , Follow all the instructions for installing ADB and IUW above.
1) Install the One Click Rooting Tool ( [APP]SuperOneClick v2.3.1 - Automatic Driver Installation! - xda-developers )
2) I had the best luck changing the rooting method to "ZERGRUSH"
Things I have learned:
1) The screen sucks. Using a stylus is definitely recommended. More-over, I have had the best results using the back side of a pencil with a gummy eraser (Weird, I know).
2) There is NO recovery mode on this tablet. Issuing commands to enter recovery from ADB will only results in a reboot.
3) boot time seems totally random. I have seen it take 30 seconds, I have seen it take 15 minutes.
4) For whatever reason, about every fourth boot my tablet tries to factory reset itself without any warning, loosing all settings, installed programs, etc etc.
5) Internal drive will randomly say that its full. only factory reset will help.
Other pictures:
View attachment 4942View attachment 4943View attachment 4944View attachment 4945View attachment 4946
HELP ME INTERNET. YOU ARE MY ONLY HOPE.
I TAKE NO RESPONSIBILITY IF YOU BRICK YOUR TABLET (HAVNT BRICKED MINE YET, HOWEVER.)
Seller:
D.N.G Superpad i7
2.Google ANDRIOD2.3
3.512MB 4GB
Memory:512MB
Storage:4GB
Boot sequence:
4)Homescreen.
IN ORDER TO RESET:
You will need:
Root access
R/W filesystems
1) SU
Rooting the Tablet:
Other pictures:
