Hdmi & sound issues!
ftanl
51
Hdmi & sound issues
anyone else experiencing ruffled sound when viewing video on HDTV?? The first few seconds sounds very clear & then it becomes distorted and choppy.. Sounds good when listening on FTii, but not through HDMI..
any ideas? a firmware issue, or simply a crappy HDMI feature?? OK for pictures, but not so good for video etc..
Another annoying thing I've noticed is when viewing a movie from sd/usb it won't exit. No stop button on the movie players & pressing the return, menu or home button does nothing.
Is this just a FTii quirk, or is there a special way to exit the movie players??
For me the movie aspect is what made me buy... are the problems I've mentioned above the norm for this device? or am I missing something?
m8 ive got the opposite from you 42" philips cineos picture no sound hdmi but it all works fine on 19" tv hdmi
Hdmi & sound issues
Basically yes. All the bugs you have are common. Unfortunately there isn't much for a fix either.
Sent from my LG OP V using Tapatalk
