HELP! APP2SD Problem...?
LiquidFire187
36
App 2 SD is confusing my internal memory for my SD Card..? I have a Coby Kyros 7127 with 4 gb of storage and 32 gb micro sd card...yet APP 2 SD says I only have a total of 3.08GB of storage...Anyone know how to fix this?
Uninstall App2SD and try AndroidAssistant. It can also move Apps to the SD card but with the software written differently it may not react the same. Also AA has many other abilities some of which you may have Apps on you tablet to perform. You may be able to remove them to clear SSD space since AA does them. Will just depend.
Sent from my VTAB1008 using Android Tablet Forum
