HELP!!how to connect on brodband stick?
myg123
8
hai,..good day...i just wanna ask how to connect to broadband stick on my coby 8048?
isnt compatible? or theres other way to connect? but how?.
ive try it once..but the usb card read the tab not the simcard..
pls help..thnxxx ahead.
Most broadband sticks simply won't work on Android because they need driver support that isn't available. I have a link in my sig with a list of some that will work.
You can try PPP Widget from the play store. It is your best shot but no guarantees.
