henrychamb
- Mar 20, 2011
- 8
- 0
I have a 7015A rooted and with the google apps following the instructions in "super easy way to root and..." stickied here, and it was working wonderfully and I was very happy except for the wake-ups every minute or so problem that I'm sure you heard about, so I installed "Autostarts" to help avoid this. I thought I was being careful in choosing the apps that would not "autostart", but it seems I wasn't careful enough. This is how my tablet works now: the tablet boots and looks normal and the hardware buttons do what they are supposed to do, but the only thing wrong with it is the screen. It can only be accessed to get into calengoo from its widget by "clicking" touching it, but the other icons don't do anything when I touch them. I thought that I would just uninstall the "autostarts" app from the internal memory connecting it to my computer, but you need to "mount" it by using the touch screen on the tablet, which I can't do. I thought of connecting a usb keyboard (or mouse) to access the terminal emulator to reinstall the back-up I have in the root of by SD card, but I don't hold high hopes for that working.
Do you have any ideas that could help me? Thanks in advance.
