HELP! Just rooted - stuck at nook color screen
Jim1970
Hello,
New to this process, please bear with me.
Just rooted my wife's NC. We bought this about 3 weeks ago, and it came with 1.2.0 on it.
Used some excellent instructions found at Facebook - of all places! All other directions I found were too complicated or assumed the reader had more skill than I have. Anyway, the instructions helped me create a CWR mSD and install cm7 and google apps. Everything went just fine, until the beast got to the nook color screen -- now it just hangs.
I re-did the install and ended up with the exact same problem.
The only error message I received during install was about the formatting of the data - the NC said "error formatting data." I proceeded, but something is not right.
I used search here with no luck.
Thank you in advance,
Jim
