i have a MID7010 tablet.I had accidentally selected the option restore factory option.After that its not working.It shows the touch screen calibration with cross hair. What should i do to get it properly.Kindly help me.
Looks like a calibration used in the Palm devices... Did you try simply touching the center of the crosshair? You may need to use your stylus to get it right.
