Help - MID7022 stuck at android load screen
rahzel
11
So I went to turn my MID7022 on today and it's stuck at the 'android' load screen. I've tried resetting it multiple times with the reset button on the back. Now I can't even turn it off.
edit: had to do a factory reset, but it boots now.
Hello i have the same problem, how did you make the factory reset thx in advance
Search the forum with words like "7022 factory reset" and you will probably find what you want... ;)
