Help needed in Battery calibration for Micromax Funbook
g.s123
Hi Everyone
I bought the Micromax Funbook P 300 ( Android ICS 4.0) tablet in September. Now it is showing problems like it shuts down when the battery is around 55-70 %. I googled and found out that the its a software glitch and that it can be solved through battery calibration. I downloaded the app Battery calibration as per the website suggestion. What i did is as follows :
1) I started the software Battery Caibration.
2) I charged the tab upto 100 %.
3) Then i unplugged the charger and allowed it to discahrge. They asked me to discharge it completely and recharge to 100%.
But while discharging it shut down at 56% and again behaves the same way even now and i see no change in the tablet.
So i wanna ask whether i have done the calibration correctly or is there some other problem? Please suggest what should i do next?
Gautam
