- Dec 9, 2010
- 153
- 10
Can anyone help me rectify this I would like to use some of the over/underclocking tools but they do not work as I do not have a governor...
I'm using a wowpad with system version deb-r2.1.1170
The other thing is that the only stats I can get for my battery is % left. There is no voltage or current according to the tools... Can anyone suggest a fix for this?
Thank you,
Richardo
Thank you,
Richardo
