help on coby kyros
xintell
11
wondering if anyone can help me connect this coby kyros 7048 to pc to change some files like vold.stab. I can only access this android through cwm since it is stuck at loading screen. or anyone can help or send me a link on how can i access the android through command prompt
No, because editing vold.fstab or build.prop will brick your tablet. Restore from the system dump that you should have made before rooting.
well it's already bricked thats why im doing this, was just asking for a way on how to do it or how can I connect it to the pc to edit the files
Bootlooping is not a brick. If however you cannot access CWM to restore from your system dump, your only option is to exchange the tablet for a new one.
